22939 Discussions
graphics on 7th gen core i5
AEast1
Is there any solution to running display driver win_64154519.4678 on a Dell intel core 15 7th gen? Dell says it is not supported, but is there any workaround?
Stefan3D
If you use Windows 10 and encounter an error message about validation, then install the driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
If you use Windows 7 or 8, neither Intel nor Microsoft support Kabylake on old Windows
Check out:
https://support.microsoft.com/en-us/help/4012982/the-processor-is-not-supported-together-with-the-windows-version-that https://support.microsoft.com/en-us/help/4012982/the-processor-is-not-supported-together-with-the-windows-version-that
All drivers' descriptions read:
7th Gen Intel(R) Core(TM) processor family
Microsoft Windows® 10 64-bit Only
You would have to modify INF and disable driver signatures at your own risk as described at
/thread/110152 https://communities.intel.com/thread/110152
This still won't help against Microsoft's blocking though.
Hello AlanEast,
Thank you for contacting Intel® technical support. I will be more than happy to help you.
I understand that you are having issues with the installation of the Intel® HD Graphics driver.
To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
  1. In the keyboard, press WinLogo key + R.
  2. In the Run box please type dxdiag and hit Enter.
  3. Click on Save All Information (save it in your desktop).
  4. Attach to this thread the TXT file with the report.
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Xavier A.
