OS: Windows 11 Home, version 11.0.22621
Processor: 13th Gen Intel (R) Core (TM) i5-1335 U
Grafic: Intel (R) Iris (R) Xe Graphics. 31.0.101.4575
I have a HP Laptop hooked up to a Generic TV.
Everything has been ok until a few weeks ago and now when playing a video from any source (YouTube, NOW TV, BBC etc) the audio starts and then there is a 3-4 second delay until the video starts and this continues with the video being 3-4 seconds behind the audio. This is through my TV speakers which use the Intel HD Audio Driver for Display Audio driver.
When I turn this off and switch the sound to my laptop speakers which use the Realtek Audio driver the audio and video are perfectly in sync as they should be.
So the issue is completely with the Intel driver. The version I have installed is dated 06/10/2023 Version 31.0.101.4887.
There is no update when I do the update check and so I do not know how to resolve this issue further, other than using my laptop speakers (which is rubbish solution).
Please, i need solution!
Hello @Sergio2306
1. When did you first notice this audio-video synchronization problem? Did it start suddenly, or has it been ongoing?
2. Have you made any recent changes or updates to your system or software before the issue occurred?
3. Is this delay consistent across all video sources, or does it vary depending on the platform (YouTube, NOW TV, BBC, etc.)?
4. Can you confirm if the delay occurs only when using the TV speakers with the Intel HD Audio Driver, or does it happen with external speakers or headphones as well?
5. Have you experienced any other audio or video issues apart from the synchronization problem?
6. Can you provide more details about the specific model of your Generic TV and how it's connected to your laptop (e.g., HDMI, VGA, wireless)?
7. Have you checked if the Generic TV has any firmware or software updates available that might address this issue?
8. Do you have any other devices you can test with the TV to see if the synchronization problem is specific to the laptop or affects all connected devices?
9. Are there any error messages or codes that appear when you encounter this issue?
10. Have you reached out to HP or Intel support for assistance with this issue, and if so, what suggestions or solutions have they provided?
Please provide us with the SSU and IGCC reports:
IGCC Report: Follow these steps to generate an Intel® Graphics Driver report for the Intel® Graphics Control Panel or the Intel® Graphics Command Center. Report for Intel® Graphics Drivers.
SSU: Please download and scan your system using our tool, Intel® System Support Utility so we can help check your system info first. Once finished downloading, open the tool, click on scan 'Everything', click next, then save the system information to a .txt file. Please provide the .txt file.
This document will be necessary to check your entire system, in order to find possible errors or incompatibilities.
As a troubleshooting step, and based on your CPU graphics, try a Clean Installation of Intel® Graphics Drivers in Windows* of the latest driver: 31.0.101.4952.
Isaac Q.
Hello Sergio2306
We hope you are doing fine.
Please provide us with the SSU and IGCC reports. And as a troubleshooting step, and based on your CPU graphics, try a Clean Installation of Intel® Graphics Drivers in Windows* of the latest driver: 31.0.101.4952.
Let us know if you still need assistance. Otherwise, we will close the tread.
Isaac Q.
Hello Sergio2306
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
I found a solution! You need to disable surround off in advanced setting of the audio setting of the Panasonic TV
nevermind it did not
