23539 Discussions
hdmi CABLE WONT SHOW SCREEN
cwhitten
My acer Aspire xc-603g , Operating system windows 10 Pro 64 (10.1.19042) ,bios P11-a2 1-23-2014, has  an HDMI port and i want to use it. However when i connect it I do not get any signal. I only can use an RGB to get signal to my "monitor" (vizio plasma hdtv). Can anyone offer a solution to my problem?
David_G_Intel
Hello cwhitten
Thank you for posting on the Intel️® communities. If this is a hardware issue you will need to check with the motherboard manufacturer for replacement options or further troubleshooting. To confirm you're using the latest drivers please share with us the following information:
  • Intel® System Support Utility (Intel® SSU) results
  • Did you try different HDMI cables?
  • Can you try different monitors/TV's?
David G
David_G_Intel
David G.
David_G_Intel
David G.
