20948 Discussions
how can I install hd 530 driver for i7 6700k win 10 64bit
VLu6
Hello
all the versions I downloaded came up with the error message "unsupported Platform'.
Is there an older version that supports windows 10? Win10 should really be supported it's not an old or exotic OS.
I do need the opencl support from the 530 gpu. I run the display from my gtx 970. Captureone however would use all gpu's in a system.
Main reason I went for the 6th skylake is the gpu.
I run windows 10 64-bit enterprise evaluation.
best regards
VLu6
nobody from intel around to at least give an answer?
Amy_C_Intel
Hello toni999,
Once you installed a graphics card on the motherboard, it will disable the Intel® HD Graphics Driver meaning that the behavior you're experiencing is expected. In this case if you're using your GeForce GTX 970 you will need to download the appropriate driver from http://www.geforce.com/drivers Drivers | GeForce.
Amy.
