23282 Discussions
how do you add a resolution under 800x600
head2
im trying to add a custom resolution that is 1920x540 but every time i try it give me an error reason bad parameters is there a way to fix this or will you never be able to make custom resolutions under 800x600
AlHill
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
head2
hey thanks for the reply i put it in notepad and copied all the information it said on the download you gave me
Sebastian_M_Intel
Hello head2,
Thank you for posting on the Intel® communities.
I can see that you opened a different thread with more details about the same problem. In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the other one.
Sebastian M.
Intel Customer Support Technician.
