23102 Discussions
how install Lucid Virtu?
I just buy an ASUS P8Z68-V PRO and an GForce GTS 450 so I tried to install the lucid virtu virtualization sw but when the discrete video card is not installed it tells me it can't be installed because it needs a discrete card. Then I install the GForce card and the software tells me there is no Sandy Bridge. What is the right procedure I do to make this works?
Allan_J_Intel1
Hi, it seems you have a configuration problem, specifically at BIOS level.
See below for some instructions about configuring the BIOS setup:
1. Upon system boot, press F2 when prompted to enter BIOS setup menu.
2. Under Configuration -> Video, set the Integrated Graphics Device option to "Always Enable"
3. If you are configuring for i-Mode, please make an additional change. Under Configuration -> Video, set the Primary Video Adaptor to "Int Graphics (IGD)"
4. Press F10 to save settings and then press "Y to exit
If you are interested in additional information check this URL:
http://downloadmirror.intel.com/19993/eng/Lucid%20Virtu%20Users%20Guide%20v1%202%20Universal.pdf http://downloadmirror.intel.com/19993/eng/Lucid%20Virtu%20Users%20Guide%20v1%202%20Universal.pdf
Allan.
Allan_J_Intel1
Allan.
Thank you very much Allan... it was more simple than I thought, now I have the lucid virtu up and running
I have the same problem, but can't find the option on the BIOS
Bios Setup : Configuration : Video : change to " always enable ".
