23787 Discussions
how to disable quick sync
tlee39
hi:
my video is HD4600.
I have a program which seems have problem with quick sync. it will sometimes freeze the whole computer. can I disable quick sync/open-cl support via windows registry? it's sad that the program did not come with options to disable these usage, so it will be great help if intel video drivers can be set for these.
thanks a lot for help!!
tlee39
hi:
it seems I can not do it?
Hi Tbsky,
It cannot be disabled because Intel® Quick Sync is a feature included on the graphics controller of your processor, I cannot suggest you, any Windows registry modification.How did you find out that the Intel® Quick Sync is the one that freezes your computer?What is the name of the program that you are trying to use?
Check this link to get more information about Intel® Quick Sync
http://www.intel.com/content/www/us/en/architecture-and-technology/quick-sync-video/quick-sync-video-general.html http://www.intel.com/content/www/us/en/architecture-and-technology/quick-sync-video/quick-sync-video-general.html
Hellen.
tlee39
hi:
thanks for reply! the program is geovision nvr system. it will use quick sync automatically if available and have no option to disable the behavior. when the system freeze, keyboard/mouse/network the whole system stop working. and the screen freeze (not black/blank). so it looks like there is some video problem. it I can disable quick sync then I can have a try, or I need to plug in another video card to test. I got two intel systems with the same problem.
Hi tbsky
Thanks for the program information, as previously mention the Intel® Quick Sync cannot be removed.
Could you please provide the model of the two Intel Systems that you have with the same problem?
Hellen.
tlee39
hi:
the cpu is core i7-4790
Hi tbsky
I did a research in regards to your question and I found that in some desktop board BIOS there is an option to enable the feature. Please note it depends on motherboard manufacturer.
I recommend you to verify if you are already using the latest graphics driver for HD 4600.
https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors https://downloadcenter.intel.com/product/81496/Intel-HD-Graphics-4600-for-4th-Generation-Intel-Core-Processors
I reviewed Geovision home page and this software if fully compatible with Windows® XP, 7, 8 and Server 2008 and 2012; 10 is not supported yet.
Mike C
Hi tbsky,
I have been checking this thread and I was wondering if you were able to resolve this problem.
Hellen.
tlee39
hi:
no, my problem still there. I am still try to patch the software to see if we can solve the freezing problem. every time I think it is solved it is back again. next time I will try to put a video card for it to test.
tlee39
hi:
I was testing if the problem cause by the RC6 power management feature. I am sure the bios has enabled the rc6 feature, and current the windows video driver registry "AllowDeepCStates=1".
if I change the "AllowDeepCStates=0" in registry, can I disable the RC6 power management feature?
thanks again for your kindly help!!
tbsky
Hi Tbsky,
To better assist you, I suggest you to login in on Intel® Developer Zone.
https://software.intel.com/en-us/forum https://software.intel.com/en-us/forum
Hellen.
