23269 Discussions
after monitor turn off.Program position is incorrect.
宗蔡4
Before vga driver is not installed, normal
After installing vga drivers
after moniter turn off.
after moniter sleep.
When I returned to windows7
Program window is not positioned correctly
For example, it was originally a 1366 * 768, 800 * 600 becomes
主機版是
http://www.gigabyte.tw/products/product-page.aspx?pid=5429&dl=1&RWD=0# driver GA-H81M-D2V
cpu
g3220t
未安裝vga驅動程式之前,都正常
安裝vga驅動程式之後
關閉顯示器後
顯示器睡著後。
當我回到windows7
程式位置不正確.
程式視窗位置不正確
例如原本是1366*768,變成800*600
Hi johncj7625,
I would be glad to help you. Please send to me the results of our test Intel® System Support Utility
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Note:
How to attach a file
Click reply
On upper right corner click Use advanced editor
Lower right section click Attach
Mike C
Hi johncj7625,
I am following your case. Let me know if you need further assistance.
Mike C
