22889 Discussions
how will i enable my virtualization on my pc?
btaba1
n_scott_pearson
That's a a pretty loaded question; since you did not describe what hardware you have. In general, there are parameters in BIOS Setup that need to be set to enable virtualization (though, these are usually enabled by default; you should check).
