23272 Discussions
i accidentally uninstall my intel hd graphics and i cant get it back.
APers9
so i deleted my intel gpu and i cant get it back because when i try using the installer it says "this operating system is not supported"
APers9
here is my pc info
LeonWaksman
  1. You have Asus ROG MAXIMUS XI HERO (WI-FI) board with i9-9900K CPU with Integrated Intel UHD Graphics 630 and NVIDIA GeForce RTX 2080 SUPER graphics adapter. In some systems when additional graphics adapter is installed, the Integrated Intel Graphics is disabled.
  2. However if your system needs both adapters installed, download and install your Intel Graphics driver:
  3. Download the latest DCH Graphics Driver Version: 26.20.100.8190 (yes this is the latest DCH Graphics Driver).
  4. Disconnect the internet.
  5. Right click on currently installed driver (in Device Manager), then click on Uninstall device. Check the "Delete the driver software from this device" option.
  6. Reboot your computer. After finishing uninstalling you should see Microsoft Basic Graphics Adapter.
  7. Now, install previously downloaded driver 26.20.100.8190
  8. Reconnect the internet and reboot your computer.
Leon
Stefan3D
Restore from a system restore point as described at
https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options
APers9
LeonWaksman
So, what you want to tell? I can see that you NVIDIA adapter installed. It is detailed in the SSU report. In most cases this is what you need and once the Graphics Adapter is enabled, the Integrated Graphics is disabled.
Leon
Khvaysakda
I have this same problem as him as I accidently uninstall the Intel hd 520 I have tried countless method but nothing work I hope you can help me
