22964 Discussions
i am unable to connect to my tv
LLewi1
Hi
I am trying to connect my pavilion laptop to my tv by HDMI and it will not detect it i am running windows 10 can any one help
AlHill
I would try HP support, or Microsoft support for this issue.
But, some basic questions:
  • Is the TV set for HDMI input? If the TV has more than one HDMI input, are you using the correct one?
  • Is the laptop set to output to the HDMI port? This is usually accomplished by a function key sequence.
  • Does the TV display "no signal" when you have verified the two questions above?
  • What graphics do you have? If you do not know, provide the complete processor model number.
Doc
LLewi1
Thanks for the help i ran all the software updates for windows and my laptop to find out it is the tv that is the problem.
AlHill
Glad you figured it out.
Can you provide some information about the TV? It might help others with a similar problem.
Doc
I am glad to hear you were able to solve this problem. Thanks for sharing this information.
Allan.
