23093 Discussions
i can't set 4k resolution for my external monitor (TV)
Rosssiiii
Hello 🙂
i would like to ask if is normal that when i set on windows 10 "duplicate screen" i can't have full resolution screen on my 4k tv, i have to accept the cropt version because i see segnal at 1080p considering the fact that my main monitor is 1080p on the notebook.
that is what i see:
Tv :4k screen (result to be cutted on top and below) ;
Notebook : 1080p
result to be ok.
I would like to have both right but don't look to be possible !
I'm able to watch the full screen in good window mode only if i set "second monitor" and i set 4k resolution for that.
n_scott_pearson
If you are duplicating a screen, then the resolution of that screen is going to be used. That's a hard and fast rule. If you want to use that TV/monitor's full resolution, you have to run it independently (use Extend these Displays, for example).
