22940 Discussions
i5 2500k CPU Graphic and AERO problem (running out of memory)
hy,
i have big a problem. everytime when i start my tv tool (dvbviewer), the memory on dwm.exe (aero) is exploding from 160mb to 1200mb (fluctuating).
After few seconds Aero is disabling automaticly (running out of memory). I let dvbviewer open and enable AERO again and then its working without running out of memory. but everytime i start the program again to watch tv, this will happen again. if watch only with my ati this will not happen.
my configuration:
Primary Graphic: i5 2500k cpu graphic with 512mb memory(on this screen running dvbviewer to watch TV) ( i tried the last 3 drivers versions)
Secondary Graphic: AMD ATI 5850
I dont know, if it is a driver problem or problem of the tool, but i think it is driver, because its running well, when i use ony my ATI card.
i hope someone can help.
best regards.
Regarding with your inquiry, according with the information you have provided the issue may be related with drivers however it seem to be your system is using "switchable graphics" therefore any driver posted on our web site won't work properly with these systems.
The computer manufacturer has released drivers specifically designed for your computer specifications.
Additionally you may contact the software developer and check for any update.
You can confirm this information at the following url:
http://www.intel.com/support/graphics/sb/CS-031103.htm http://www.intel.com/support/graphics/sb/CS-031103.htm
Dago MC.
