Bought a new computer and upon finishing Windows 10 Pro installation, noticed that the display connected on the 530 keeps showing artifacts-flickers every now and then, sometimes it goes black for 1-2 seconds then comes back.
When I thought it was the display, I tried it on the old computer, and everything worked perfectly.
I thought that it was a problem on the memory, tried with 1 stick (after running memtest) and the problem still existed.
Updated the drivers to the latest - still problem persists.
Finally went to google the problem and found out I am not the only one with the GPU flickering - it's so dissapointing.
Any ideas?
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
530 HD displays artifacts, flickers, goes black, etc. etc.
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
every single time - every 2-3 minutes something of the above happens
Hardware (HW)
Brand and Model of the system.
Intel Skylake HD Graphics 530 (i7 6700k)
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
Hybrid - NVidia GeForce GTX650
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)EFP = External Flat Panel (Monitor you plug in)<td style="padding: 0 5.4pt; border-right-width: 1pt; border-bottom-width: 1pt; border-style: none solid solid none; border-right-color: windowtext; border-b...
- « Previous
- Next »
Hi fufoua,
Thank you for your feedback. I regret the inconvenience experienced.
Mike C
i got no probleme with fleckering screen with hdmi- dvi cable but with hdmi -hdmi i got probleme on some monitor and some hdmi cable that make more or less artefact. look like the cable is not connected properly.
i am trying 16 bit color look like problem is gone, i am testing it right now
when i uninstall intel driver got no probleme too but can t play game
my computer:
i5 6600k ,
z170x gaming 5,
2x8 ripjaws 5 red 3200 (run at2133mhz)
- « Previous
- Next »
