22940 Discussions
i7 8700k + iGPU HD630 + nVidia GTX 10603GB
ZBala
I use video encoding in Handbrake a LOT. Therefore I need to keep iGPU activated for me being able to use QSV when I encode. Now when I start ANY 3D application which runs obviously on my 1060 after a while screen flickers and I see the application screen and the desktop in a super-fast flickering manner. Alt-Tab solves the problem for a couple of minutes.
iGPU deactivated the problem disappears.
Any ideas?
Stefan3D
You did not mention your current driver version.
Try older or newer drivers from this list https://downloadcenter.intel.com/product/98909/Intel-HD-Graphics-630 Downloads for Intel® HD Graphics 630
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface (ignore prolog about MS surface)
Stefan3D
ZBala
Thank you for your answer. Excellent. Problem solved!!!!!
Faulty driver: 15.65.5.4982
Proper driver: 15.60.2.4901
Cheers,
Zoltan
