22912 Discussions
igxelpicd64 crashes after playing HEVC video using the qt framework for a long time
moliyadi
I used qt + libvlc to play multiple HEVC(4:2:2 10-bit  Range Extension) videos in one application at the same time. The UHD 770 can be hardware-decoded, and everything works fine for short playback, but the Qt framework will crash if played for several (5 or 6) hours.
crash info like below, If anyone can help, thanks.
20230323190155-Debug: MainWindow::event:WindowActivate (|0|)
20230323190155-Debug: MainWindow::changeEvent QEvent(ActivationChange, 0x7acbd5b840) (|0|)
20230323190155-Debug: CreateCrashHandlr:ErrorCode:c0000005 ErrorAddra7897150 ErrorFlag:0 ErrorPara:2 (|0|)
20230323190155-Debug: Crash CallStack: (|0|)
20230323190155-Debug: N/A () : [ igxelpicd64 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QOpenGLTextureBlitter::blit () : [ Qt6OpenGL ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QPlatformBackingStoreOpenGLSupport::~QPlatformBackingStoreOpenGLSupport () : [ Qt6OpenGL ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QPlatformBackingStoreOpenGLSupport::composeAndFlush () : [ Qt6OpenGL ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QPlatformBackingStore::composeAndFlush () : [ Qt6Gui ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWidget::y () : [ Qt6Widgets ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWidgetPrivate::shouldDiscardSyncRequest () : [ Qt6Widgets ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWidgetPrivate::syncBackingStore () : [ Qt6Widgets ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QApplicationPrivate::notify_helper () : [ Qt6Widgets ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QApplication::notify () : [ Qt6Widgets ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QCoreApplication::notifyInternal2 () : [ Qt6Core ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QGuiApplicationPrivate::processExposeEvent () : [ Qt6Gui ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWindowSystemInterface::sendWindowSystemEvents () : [ Qt6Gui ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWindowSystemInterface::flushWindowSystemEvents () : [ Qt6Gui ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: qt_plugin_query_metadata () : [ qwindows ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: CallWindowProcW () : [ USER32 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: glPushClientAttrib () : [ opengl32 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: DispatchMessageW () : [ USER32 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: SendMessageTimeoutW () : [ USER32 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: KiUserCallbackDispatcher () : [ ntdll ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: NtUserDispatchMessage () : [ win32u ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QEventDispatcherWin32::processEvents () : [ Qt6Core ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QWindowsGuiEventDispatcher::processEvents () : [ Qt6Gui ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QEventLoop::exec () : [ Qt6Core ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: QCoreApplication::exec () : [ Qt6Core ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: N/A () : [ 5GBackpackClient ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: BaseThreadInitThunk () : [ KERNEL32 ] (File: N/A @Line N/A ) (|0|)
20230323190155-Debug: RtlUserThreadStart () : [ ntdll ] (File: N/A @Line N/A ) (|0|)
Jean_Intel
Hello moliyadi,
Thank you for posting on the Intel️® communities. We understand that you are having issues when playing multiple HEVC in one application.
  • You mentioned that the issue is when you play multiple videos at the same time. Does the issue occur when you play a single video? How many are "multiple" videos?
  • Did the system use to work as expected before?
  • Could you share a video showing the issue?
Also, it is important to mention that there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM). Please, make sure that the issue persists after a clean driver installation of the 31.0.101.3302_2 version.
Finally, we noticed that the BIOS version installed on your system is 2.03, and the latest version available on the AS Rock website is 11.02. Try updating the BIOS to the latest version. If you need more recommendations about the update process, you should contact the motherboard OEM for more recommendations.
Jean O.
Jean_Intel
Hello moliyadi,
We hope you are doing fine.
Jean O.
moliyadi
Thank you for your reply. I am trying different schemes you provided. I will reply here if there is any new progress. Thanks.
Jean_Intel
Hello moliyadi,
We understand that you are still trying our recommendations, and we would wait to confirm the outcome of our advice. Let us know if you face any inconvenience with one of our suggestions.
Jean O.
Jean_Intel
Hello moliyadi,
Jean O.
Jean_Intel
Hello moliyadi,
Best regards.
Jean O.
