23272 Discussions
in a page intel website says that FIFA 15 is playable in intel hd 4400 graphics with core i5 4200u at 30 fps.... Is it real or not?
FAbir
I want to buy a laptop (hybrid laptop) without dedicated gpu. if intel hd4400 is strong enough to play FIFA 15 in 30 fps it will be enough. But I have to be sure that the intel hd 4400 will handle it very well. plz help me is the list is true or not..
the link is given below
http://www.intel.com/support/graphics/sb/CS-034979.htm Intel® Graphics — Playable Games List for Intel® HD Graphics 4200/4400
Allan_J_Intel1
If the game is listed on the playable site, this means has been tested out of the box at 30 FPS.
I see on the list that Fifa 2015 is playable.
I would recommend checking with other community members to see if the have experienced higher FPS when running Fifa 2015.
Allan.
FAbir
Is it applicable for desktop/laptop or both
llybx
Try checking at http://www.notebookcheck.net/Intel-HD-Graphics-4400.91979.0.html Intel HD Graphics 4400 - NotebookCheck.net Tech if you're not sure
as you can see there's
Aspire V 15 Nitro VN7-571G-56NX
29.1 fps
Intel Core i5 4210U 1.7GHz
HD Graphics 4400 (200-1000 MHz), 2048 MB (1000 MHz) , 10.18.10.3643
4 GB RAM
so yeah, should be 30fps.
keep in mind it depends on what your ram config is, the laptop above is running on single channel mode. could be a bit more fps with dual channel mode and latest drivers.
Allan_J_Intel1
Allan.
FAbir
llybx
29.1 fps
4 GB RAM
