23606 Discussions
increasing memory on intel gm45
hello i want upgrade my ram now i am using 2x2gb totaly 4gb pc2-6400 800 mhz 200 pin and i wonder can i change these rams with 2x4gb totaly 8gb pc3-8500 1066 mhz 204 pin rams, does 204 pin effect this upgrade by the way my chipset is intel gm45
DArce
Valued Contributor III
There might be many different options for you to upgrade or replace your memory on your system. We recommend contacting the computer manufacturer as they have set the valid compatibility list between the computer, the BIOS. The system manufacturer should also provide the specifications on what technologies from the processor might or might not be supported.
