23272 Discussions
Cant reinstall Intel Graphics and Media Control Panel
I recently used the recovery disks on a toshiba Sattellite A665-SP6011M to set my laptop back to the way it was before unpacking. After that, the control panel for the intel graphics dissapeared. I've tried several times to download the drivers from toshiba and intel download center, but none of the ones I've tried worked.
Which driver do I have to download?
CPU: Core i5-M460
Chipset: HM55
Ps: used the intel driver updating utilty and says nothing, it just recognized my NVidia.
DArce
Valued Contributor III
If your system features a Nvidia* video controller and an Intel(R) video adapter, then your system most likely features switchable graphics.
These systems use special drivers provided directly from the laptop manufacturer. So in this case I suggest you to check with them to see how you can enable the secondary video adapter and to load the drivers required for it.
