23832 Discussions
installing help
I'm trying to install the latest version of Intel HD Graphics Driver for my pc.
my os. is win. 7 ultimate 64 bit.
Processor: Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz (4 CPUs), ~2.9GHz
Memory: 4096MB RAM.
System Model: H55M-USB3.
DirectX Version: DirectX 11.
current Driver Version: 8.15.10.2559.
tried to install from here
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=Intel%C2%AE+Q45+Express+Chipset http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Graphics&ProductLine=Desktop+graphics+drivers&ProductProduct=Intel%C2%AE+Q45+Express+Chipset
and i got this error massage:
"this computer does not meet the minimum requirements for installing the software".
then tried from here
http://www.eightforums.com/graphic-cards/7654-latest-intel-hd-graphics-driver-windows-8-a.html Latest Intel HD Graphics Driver for Windows 8
, which refer to first generation processors (winch i think my is) and it gave again an error massage:
"this setup failed to install one or more device drivers, setup will exit"
can anyone help me with this issue ?
it gives me a different error notice then the 2 which mentioned in the link you gave me.
the massage is:
what should i do ?
thank you.
DArce
Valued Contributor III
You can try uninstalling the driver that is currently installed. That is done through the control panel, under programs and features; locate the Intel® Graphics and media driver (or anything similar) and then uninstall it. After that is done, try to load the driver again or try the instructions posted on this article:
http://support.intel.com/support/graphics/sb/CS-022355.htm http://support.intel.com/support/graphics/sb/CS-022355.htm
If the issue persists, you may need to check with Gigabyte for a customized driver provided by them and check if the issue persists with their drivers.
find those 2 in 'program files x86' - 'Intel'(didn't find it in 'program and features'):
1. Intel(R) Graphics Media Accelerator Driver .(dated 2 February 2010)
2. Intel(R) Processor Graphics ( dated 3 January 2012).
a. which of them i should try to uninstall?
b. if I'll remove the existing driver will i see anything on my pc monitor/screen so i'll can to install the updated driver?
i
DArce
There should be only one installed. I am not sure if this happened due to a failed attempt to install a driver for another type of video controller, or if this operating system was installed using another system (and older one) and then you moved the hard drive to this new system without reinstalling the operating system.
Anyhow, you can remove both and still you will get video on your system to be able to keep using the system and load the correct driver
o.k i found driver location.
uninstalled it.
then i had still problem to install the new driver.
at the end, i'm not sure exactly how, somehow windows installed successfully the driver it's exe. i downloaded earlier.
now i have installed ver.8.15.10.2827 which i believe is the latest one.
DArce
Yes, that is the latest generic driver we provide.
I am glad that you have been able to update the driver in your system.
thank you.
you can close this topic as solved.
