22022 Discussions
intel节能模式导致笔记本卡顿
好陈
今年2月买的华硕K450JF,Intel 酷睿i7 4700HQ 四核心/八线程,DDR3 4G 1600MHz ,NVIDIA GeForce GT 745M 2G显存,1TB硬盘
卡顿指笔记本总是莫名其妙且随机出现的卡顿,具体表现是:
1.有时无法开机,睡醒后无法唤醒,容易蓝屏
2.总是突然卡顿,换固态硬盘后更容易碰到.
3. 文件系统会突然消失
ps:操作系统尝试过win8,win8.1,Ubuntu14.01,fedora20/21,centos7,均碰到卡顿问题.
维修路线:硬盘坏道检查(无坏道)->换机械硬盘->换主板->换固态硬盘(三星 850 Pro)->换内存,全部方法都无法解决,后来送到华硕总厂检测说"是intel节能模式导致的,我们无法处理".
请问针对这种情况,你们intel有好的处理方法吗?
more log: https://bugzilla.kernel.org/show_bug.cgi?id=74961 https://bugzilla.kernel.org/show_bug.cgi?id=74961
Silvia_L_Intel1
Hello Meilihao, thanks for joining the Intel Graphics community.
I recommend you to post your issue in English, since we need to use a translator and sometimes it does not provide the real issue or some words are not correctly translated.
I would like to inform you that the Intel power saving mode driver is provided by the OEMs (Original Equipment Manufacturer) since they need to customize it.
If you want to check if the processor is defective, you can run the Intel Processor Diagnostic Tool. It will help you to determine if the processor has any issue. http://www.intel.com/support/processors/sb/CS-031726.htm Processors — What is the Intel® Processor Diagnostic Tool?
好陈
Thank you for your answer,but Asus Engineer told me it is caused by intel power saving model and they had no idea to solve the problem.
I don't know who is right,but i was puzzled by the problem for 11 months.So i need more help, for example how to turn it off on linux or windows?
Silvia_L_Intel1
From our side you can try installing our latest graphics driver provide at the following link, however bear in mind that we provided generic drivers; and sometimes these cannot be installed on other systems or the installation of them could overwrite their customizations and possibly change the functionality of the graphics. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3720 https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3720
As I mentioned before, the Intel power saving mode driver is provided by ASUS, if the installation of our graphics driver does not fix this behavior, the next step will be to check if there is a new BIOS version available for your system so you can install it.
If the problem persisted please contact ASUS so they can replace the unit.
