23784 Discussions
intel HD 520 Graphics
WDuke
When installing drivers this is what shows.What do I do now
Hello duker,
I understand you are your computer is missing the Intel High Definition DSP driver.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Was there any software or hardware change before the issue started happening?
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Hello duker,
I was wondering if you still need assistance regarding the driver the computer is missing. In case you still assistance just let me know.
Fred D.
