22941 Discussions
HD 4000 Card does not want to extend to three monitors simultaneously
NCoop1
Good day
I have a dell latitude e6330
3.0 ghz intel dual core i7 - 3540m
It has a intel HD graphic Card 4000
OS - Windows 8
I have a VGA slot and Mini HDMI
Screen 1 - Mobile PC display (Laptop screen) - Connecting interface - N/A
Screen 2 - Samsung syncmaster p2450 - 24INCH - Connector interface - HDMI
screen 3 - Hp 17inch - connecting interface VGA
Machine does not have a display port only VGA AND MINI HDMI
I am trying to extend my screen to all desktops , however it does not allow me . i see all three but cannot all three at the same time
I can have screen 1 and screen 2 , but then screen 3 defaults to "disconnect this display"
I can have screen 2 and screen 3 , but then screen 1 defaults to "disconnect this display"
I can have screen 3 and screen 1 , but then screen 2 defaults to "disconnect this display"
I have tried every combination under screen resolution . however I cannot get this to work
I would like to extend all three screens
Thank you
Hello Navzo,
I understand you are having troubles setting up three displays configuration.
Let me apologize for any inconvenience this issue may be causing to you.
Three independent displays are supported in the following configurations:
  • If two of the displays are DisplayPort* monitors.
  • If one of the displays is an Intel® Wireless Display (Intel® WiDi).
  • If the built-in display is an Embedded DisplayPort* (eDP).
Most likely the motherboard of the laptop was not built to support three displays configuration. This is hardware limitation of the motherboard itself, not a limitation of the graphics controller.
The following link will provide more information about three displays configuration http://www.intel.com/content/www/us/en/support/graphics-drivers/000005556.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005556.html
Let me know if you have or not any other inquiry.
Fred
Hello Navzo,
I was wondering if you have or not any other inquiry regarding three display configuration. In case you still need assistance just let me know.
Fred D.
NCoop1
Hi
Thank you for the reply , I am still not able to connect three monitors
Hello Navzo,
In order to help you better I would like to get the Intel Graphics Driver Report. This link will show you how to generate it https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html https://www.intel.com/content/www/us/en/support/graphics-drivers/000005848.html
Fred D.
Hello Navzo,
Fred D.
