Hello everyone !!
Hope you guys are doing well.
I am having trouble with intel(R) dynamic tuning technology updater component it shows error (28) in device manager. I have a acer Predator helios 16. I am new here please let me know what information to provide.
Warm Regards.
U.A. Sumedh
TheGame_810, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, could you please provide the model of your Intel® processor?
As an option, you can attach the SSU report that contains all that information by following the instructions in the link below:
Albert R.
Hi Alberto
I have Asus SCAR 18 and I am having trouble with intel(R) dynamic tuning technology updater component - it shows error (28) in Device manager. I downloaded the driver from ASUS webpage and instaled it, but Device manager still shows the driver as not installed. I also attached System Support Utility log.
Hello TheGame_810, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello TheGame_810, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
Hi Alberto
I have Asus Stix G18 and I am having the same trouble with intel(R) dynamic tuning technology updater component it shows error (28) in device manager. and when I wanna install the Driver from asus Drive It installed by Still showing not installed in Device manager
Please see the attached file
Hi, I have the same problem as you. Did you fix the problem? Thanks.
in the device manager it appeared like this for me
The drivers for this device are not installed. (Code 28)
There are no compatible drivers for this device.
for my ROG STRIX G814JI I solved the problem after installing the following driver DRV_DTT_Intel_SZ_TSD_W11_64_V101140139039_20231117R
I hope it will help you to solve the problem😁
Thank you very much, that helped. Do you happen to know what caused it (update, software, firmware,....)
I don't know exactly what caused it but it is most likely because windows update does not find any driver to solve this problem
and if even in windows update it does not find the driver to install it then clearly the driver will not be installed even when installing windows
for example, I bought the laptop without windows preinstalled and when I started to install windows the first time it was a real adventure due to the lack of drivers
the first time I encountered the lack of a driver for ssd (micron)
then something had to be disabled through the bios
when I updated the bios once, the boot path was broken, then enter the bios again and search and restore the boot path
luckily for me, I've had to deal with all kinds of problems over time due to the lack of drivers and I don't really give up until I find a solution to the problem😅
O my God, I've been trying to fix this problem for 4 months! That was the only thing that actualy worked! Thank you so much!
Idk what happened to him but You solved my problem bro , Thx a lot ❤️
Thank you. It worked for my Asus ProArt workstation.
Note that I had to extract before running. Choosing the "Run" alternative gave me an error message, saying that it isn't supported on my operating system, which IS W11.
However, extracting first and then running AutoSetup in the extracted directory worked "smooth as silk".
I installed this driver package and it seemed to have fixed the issue, but after further investigation it only hid the device and changed the error code of it to Code 45 (Device is not plugged in). Im not certain if this is actually the reason for the error 28 in the first place or if your driver package only hides that there is a problem. Does anyone have the same issue?
Muito obrigado, funcionou com meu Acer Nitro ANV15-51
I have an acer predator helios 16 and this exact problem. what can i do?
you can also try to find the driver with Driveridentifier
but it will not automatically download the driver, you have to download it manually
after scanning the drivers
look there at
intel(R) dynamic tuning technology component updater
after you click download try to install the latest DRV_DTT_Intel_SZ_TSD_W11_64
but see if you can find where write oem if it is also for acer and try
if you see or think you can't handle it, try the driver I posted, maybe you'll solve the problem 😁
Hi Everybody
I've an Asus H7604JV the Studiobook ProArt, and i meet the same problem
Intel DTT is on error in the Dzevice Manager of Win 11
I tried to uninstal and reinstall the driver to fix the problem (by using DPTF_DCH_Intel_Z_V1.0.11200.30652_31666)
That fix the problem at the next startup, But the error ends up reappearing during a next reboot !!!
I don't know what to do to fix this problem.
Waiting for help and a solution.
Best regards
V.P.
try the driver that I uploaded
maybe you can solve the problem
Same problem I had... try this driver and I believe it will be gone. Mine has same symptoms.
https://rog-forum.asus.com/t5/downloads-for-motherboards/drivers-intel-dtt-gna-5xx-6xx-7xx/td-p/905856/page/2
