22785 Discussions
intel RTS 9.6 unable to add non-member disk to array in order to rebuild
I'm running a RAID1 (2 disk) and have the following issue.
The drive at port 0 has been disconnected and it made the array mark as 'degraded'.
In fact the drive is healthy , it was disconnected on purpose.
Afterwards the drive was connected again and it shows as 'non-raid' member in the OROM ( ctrl-i ) utility at startup,
where i have no option to switch it back to a member disk and start the rebuild.
Also in the RTS concole in windows , it is not giving me an option 'rebuild' somehow to the disk.
I guess it is marked as 'BAD' somehow as i can see the disk as 'missing' ( serialnumber with suffix ':0' which i guess is the portnumber)
while at the same time it is als marked as present and connected to port 0.
How to proceed to 'unmark' the disk as bad and do a proper rebuild ?
Any help is appreciated.
Allan_J_Intel1
If you had a RAID 1, you can actually break the RAID structure, just enter CTRL-I and select the drives you want to see as Non Raid, then you can use the Intel Rapid Storage and recreate you RAID 1.
Open the Intel Rapid Storage software, go to Create and select Real-Time data protection option
