23838 Discussions
intel UHD versus iris Xe
JTKira
I recently bought a Lenovo laptop with i5 13420H 16 ram dual channel memory. Its marketing included an iris Xe as the iGPU. When I checked online it said intel UHD. After understanding the dual channel memory deal to use iris Xe at full potential, I assumed it will be alright. But after buying the laptop, it shows intel UHD. I tried checking with Lenovo vantage and cpu-z and gpu-z and it was the same, with gpu-z showing "Intel UHD graphics 64EU Mobile" which is neither of the ones I kept seeing online (either 48EU "UHD" or 80EU "iris Xe"). I saw a post which asked the exact same question, but there was no answer, only an acknowledgement statement from a moderator. Can I get a confirmation on if I was scammed or was the seller just as confused as I was or does the performance equal the iris Xe, but it is a display issue or something.
Debbie219Adams
Hello!
Your Lenovo laptop with the i5‑13420H isn’t a scam—the chip officially comes with Intel UHD Graphics (64EUs), which sits between the entry‑level 48EU UHD and the 80EU Iris Xe. Lenovo’s marketing often uses “Iris Xe” as a blanket term for Xe‑LP architecture, but Intel labels the 64EU variant as UHD. Performance is better than 48EU UHD but below full Iris Xe, and with dual‑channel RAM you’ll get the best out of it. The mismatch is branding confusion, not fraud.
