23525 Discussions
intel Xess DLSS not shwoing suddenly
ruh-n
i was playing THE FINALS and after few graphic customization the INTEL XESS DLSS is not showing up in the option i have tried to re-install the graphic driver but the fps is around 40-60 average ,, i have also tried to re install the game but the result is same.
Jose_Intel
Hello @ruh-n
Thank you for posting on the Intel️® communities.
We sincerely regret you are experiencing issues using one of our products, we will be more than happy to assist you.
Please answer the following:
·      What are the “customizations” you are talking about?
·      If you revert the changes, does the issue disappear?
·      Were you using an older graphics driver?
·      Please provide a screenshot where the option should be.
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Graphics Command Center
Jose B.
Jose_Intel
Hello ruh-n
We hope you are doing fine.
Were you able to check the previous questions?
Let us know if you still need assistance by attaching the required reports
Jose B.
IsaacQ_Intel
Hello ruh-n,
Best regards.
Isaac Q.
