- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
so i have been facing this same error for the past year or so and now im sick of it, i don't even know if this is dsa fault or not, i even tried removing the graphics completely and use display driver uninstaller (ddu) to clean and restart and reinstall the graphics but it doesn't work either...
theres a few rare times where it managed to install but turns out its not, the latest like this is ver 32.0.101.7080 but as you can see later down, its in fact not...
every single time when i tried updating, i click on clean installation, didn't customize, and reboot after its done, but it all failed with this same error code 1000... i saw that it means that it has driver conflict or something
i even tried manually installing the latest driver but its the same as dsa
here's some info about my laptop and a ssu report attached:
HP Laptop 15s-fq5xxx
Bios
Version: F.22
Date: 2024-04-23
Processor: 12th Gen Intel® Core™ i5-1235U
Intel® Iris® Xe Graphics
- Version: 32.0.101.5542
- Date: 2024-08-06
Intel® 11th – 14th Gen Processor Graphics - Windows*
Installation failed with error code 1000
This download installs Intel® Graphics Driver 32.0.101.7082 for 11th-14th Gen Intel® Core™ Processor Graphics.
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi zyyytan,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist you with your concern. To better understand the issue and provide accurate support, could you please share the following details:
- Are you currently using any antivirus or security software that could be blocking driver installations?
- Is Windows Fast Startup enabled on your system?
- Are you installing the driver with administrative privileges (e.g., right-click and select Run as administrator)?
- Which installation method are you using?
- Intel Driver & Support Assistant (DSA)
- Manual download from the Intel website
- Windows Update
- Device Manager update
- When using Display Driver Uninstaller (DDU), do you:
- Run it in Safe Mode?
- Select the Clean and restart option?
- Disconnect from the internet during the process?
- Do you have any other graphics-related software installed (e.g., GPU monitoring tools, overclocking utilities, or other manufacturer’s graphics software)?
- Is this problem occurring only with Intel graphics drivers, or do other drivers also fail to install?
- Have you tried installing an older version of the Intel graphics driver to check if the issue persists?
- At what stage does error 1000 occur?
- During extraction?
- During the actual driver installation?
- At the very end?
- Have you checked Windows Event Viewer for any related error messages during the failed installation attempts?
If you have any additional questions or need further assistance, please don’t hesitate to contact us.
Kent Russel P.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I am having the same issue with Intel Graphics Driver 32.0.101.7084 for 11th-14th Gen Intel® Core™ Processor Graphics error code 1000.
A CSR even trouble-shooted my system and manually downloaded it.... I think. But it appears to have the "old" version on there now...
Version: 32.0.101.7084
Release date: January 23, 2026
Edition: Microsoft Windows 11 Home (64-bit)
Version (Build): 25H2 (10.0.26200)
So I messed with it. First a screenshot of before update. Then Driver Update (automatic check in windows) thru Device Manager seemed to revert to an even OLDER version (see screenshots).
Frustrating since I do not have the time devoted to do this TWICE! I wish they would just create a new update that will not have these download issues.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
I have been having the same issues. I have an Alienware M18 R2 Intel Core i9-14900HX processor with 64 GB memory and 4 TB of storage running Windows 11 x64.
Your automated app brings up the latest updates to install and most of the time works but this and another app have been received error code 1000 each time I try to install the update
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi zyyytan,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi zyyytan,
I hope you're doing well. As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
