23282 Discussions
intel graphics command center can't Merge 2 monitors as Portrait with Portrait(Flipped)
Wongsub
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
Wongsub
hi,
sorry for the late response, my system information as attached file.
David_G_Intel
Hello Wongsub
Thank you for posting on the Intel️® communities. Please share more information with us:
  • Did this start with Windows 11*?
  • How do you connect the each monitor?
  • Do you use any adapters/converters?
  • Did it work before?
  • Did you test different graphics drivers?
David G
David_G_Intel
David G.
Wongsub
I think you need to try Combine Desktop 2 monitors Portrait with Portrait(Flipped) you will know my concern. thank you.
David_G_Intel
Thank you for the information Wongsub. As a friendly reminder, we need the above information to proceed with this request.
David G
David_G_Intel
Hello @Wongsub
Please let us know once you have the above information.
David G
David_G_Intel
David G.
