23783 Discussions
intel graphics control panel will not start
ifore
ive updated everything ever since ive been upgraded to win 8.1 its been like this the graphics control panel will not start ive had to manulay start it. i narrowed it down to the GFXV4_0 application it will not start but if i use the 2_0 application it works why is it doing this? please help.
AlHill
What is your processor model number?
What graphics do you have?
What operating system are you currently using?
Doc
ifore
* intel core I7 3537u
* intel HD 4000 using current up to date driver 2017
* Windows 8.1 x64-bit
ifore
Stefan3D
Try the solution from here:
ifore
ive done everything used samsung's own drivers no change, ive looked on youtube no help. i looked at sys notification service it says it's running. but obviously it's not
or i have no access to it.
corei100, I am sorry to hear that!
I would like to recommend to uninstall and re-install the latest driver with the steps below, this will help to make sure that driver is properly installed.
Uninstall steps
  1. Open the Device Manager using the steps provided for your operating system:
  2. Expand the Display Adapters section.
  3. Find the Intel Graphics Driver.
  4. Right click Intel Graphics Driver and select Uninstall.
  5. Select the check box Delete the driver software for this device.
  6. Reboot the computer after uninstall process has finished.
Re-installation steps
  1. Login with administrator privileges
  2. Open Control Panel
  3. Open Device Manager
  4. Click on "Display adapters"
  5. Double click "Intel HD Graphics"
  6. Click on the "Driver" tab
  7. Click on "Update Driver" button
  8. Click on "Browse my computer for driver software"
  9. Click on "Let me pick from a list of device drivers on my computer"
  10. Click on "Have Disk" button
  11. Click "Browse"
  12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
  13. Navigate to the Graphics sub-folder
  14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS</li>
  15. Click "OK"
  16. Click "Next", Driver should now be installing.
  17. If successful, click "Close", Reboot.
Here you can find our latest driver for your graphics controller and operating system: https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499 Download Intel® Graphics Driver for Windows* [15.33]
Please share your results.
Amy C.
ifore
ive recently reinstalled windows 8.1 and a few days later they hade 43 updates one of them re-updated the driver to 2017 up form 2015. ive also had trouble with adjusting the brightness threw the sliders in power management. this isn't a big problem but would like to hae solved also i thing there is something wrong in general with intel's 2015 graphics driver. the only way i could get the 2017 driver was ether manually or now threw win 8.1 install.i thank you all for your help though.
/thread/116541 corei100, my apologies for the inconvenience.
I have sent you a private message, please check your inbox for it.
Amy C.
