23784 Discussions
intel graphics control panel
JMull8
My intel graphics control panel no longer opens to where i can see it on the screen. All i have is the icon on the bottom taskbar. When I right click on the display screen and select Intel Graphics Setting it pops up like it is working but then goes to the bottom taskbar as an icon and you can not open it to make changes or selections. All help will be appreciated.
Jimmy
Hello JLMullins53
Thank you for joining the community.
In order to help you better, I would like to gather more information about the configuration you have on the computer. Please attach to this thread the TXT file the Intel® System Support Utility will generate: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Steps to save the report:
  1. Run the utility.
  2. Click on "Scan" to get the scanned system.
  3. Once the scan is complete click on "next".
  4. Use the "save" option, save the report to your desktop.
  5. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
When you use the option of the right click on your desktop are you able to use the Intel HD graphics control panel without any problem?
Leonardo C.
Hello JLMullins53
I was checking your case and would like to know if you have been able to get the report.
Leonardo C.
