22662 Discussions
intel hd 4000 3 monitör
Muratdede
  • Merhaba
  • Acer Aspire V3-571G laptop kullanıyorum bu bilgisayar windows 10 64 bir sistemesahip ve intel hd 4000 ekran kartı var bu bilgisayarda 3 monitör kullanabiliyormuyum bilgi verebilirseniz sevinirim
n_scott_pearson
While your processor's Intel HD Graphics 4000 engine is capable of supporting three independent monitors, the configuration of this particular laptop makes it impossible to take advantage of this capability. You would need a DisplayPort connector to have any chance of supporting two external monitors. With only a HDMI connector available in your laptop, only a single external monitor can be connected.
Ok, that said, there *is* a way to connect a third (second external) monitor. You can purchase a USB-based graphics adapter, such as this: https://www.amazon.com/dp/B08HN2X88P. If you want to have three external monitors, there is an adapter for that as well: https://www.amazon.com/dp/B0725K1MHH. Obviously, these adapters are costly - and I have no idea if available in your country - but they work (just don't try to use them for gaming; they are too slow for that).
Hope this helps,
AndrewG_Intel
Hello @Muratdede
Thank you for posting on the Intel® communities. We hope that the assistance provided by the community has been helpful.
Also, we would like to inform you that due to the Intel® HD Graphics 4000 has been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
You can verify this product's discontinuance status at the following links:
Andrew G.
