i bought new laptop (CYBERPOWERPC Tracer II) with 1070gtx and i already installed update of intel hd graphics
but the problem is intel hd graphics control panel as you see here
even optimus technology nvidia not appear it
but it's appear in device manger
how can i solve this problem
链接已复制
Check graphics settings in BIOS.
Check device manager for yellow bangs.
Install Intel before NVIDIA driver.
Cyberpower's https://www.cyberpowerpc.com/support/ support forwards to Intel and NVIDIA, so generic drivers should work fine.
Did you install an old Windows 10 version that has trouble with NVIDIA Pascal GPUs?
If so, re-check after "Windows' Fall update" scheduled for tomorrow.
thanks i already check all this above
bios was last update but there's no options of graphics settings
and as you see here in device manager is installed ok
there's no intel hd graphics control panel not on desktop
and windows it's with last update
optimus technology nvidia not working
any idea for solve this problem
Check the registry, it must contain following entries
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\Hybrid]
"HybridPlatformRole"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NVTweak]
"OptimusProfilesInstalled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\Optimus]
"Installed"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\CoProcManager]
"ChipsetMatchID"="8086xxxxyyyyzzzz"
Numbers in last entry must be same as in
device manager / system devices / Mobile 7th Generation Intel Core Host Bridge - xxxx / Hardware ID
PCI\VEN_8086&DEV_xxxx&SUBSYS_zzzzyyyy
Otherwise run manually
c:\Windows\System32\igfxCPL.cpl
c:\Windows\System32\GfxUIEx.exe
thanks for reply and i'll reply for each one
i didn't find this last part root Hybrid so should i create it?
i found this so i leave it as same
also i didn't find this last part root Optimus so should i create it?
my ChipsetMatchID="808659101D051030"
and here pic about
so what must i do?
At first check if "Windows Fall creators" update coincidentially fixes your issue.
Create a system restore point before you manipulate registry
https://support.microsoft.com/en-us/help/4027538/windows-create-a-system-restore-point
"Hybrid" was the predecessor of Optimus. Don't know what this key exactly does.
I would create the keys, reboot, then install GeForce driver on top of the old one.
Regarding ChipsetMatchID - you looked at the wrong location. See my screenshot for reference.
If you don't see sth. similar, install https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility- Intel® Chipset Device Software (INF Update Utility)
dmw2200 schrieb:
i have diffidence here as you see
Ignore the wording, only the number 5910 is relevant. It's the same as in ChipsetMatchID, so at least the chipset driver works correctly on your rig.
Otherwise i'm running out of clues
dmw2200 schrieb:
thanks for replay do you mean there' no solve for my problem in this case?
If no one else here has another idea i suggest to contact CyberPowerPC https://www.cyberpowerpc.com/support/ Support
hello guys.
i found a solution for this issue..
you must update your windows to Fall Creator Updates and install latest intel driver!
- 2 of latest and recently update of intel driver isnt compatible with older windows build and update!
if this problem appeared again you must download and insatall fresh windows 10 with latest update released in october (fall creator update) and install driver...
dmw2200: We are sorry to hear the problem persists. At this point the best thing to do now will be to get in contact directly with Cyberpower for further warranty or technical assistance:
https://www.cyberpowerpc.com/company/contact.aspx
Alberto R
dmw2200: You are very welcome. Please try their forum support, you can always refer them to this thread, you will receive peer to peer support and they should be able to further assist you:
https://www.cyberpowerpc.com/forum/ https://www.cyberpowerpc.com/forum/
Alberto R
