22654 ディスカッション
low fps on ff14 when ff14 showes many charator's shadow
matinekonya
ビギナー
4,986件の閲覧回数
I login in ff14. There are many charactor is in same area(about 142 charators). In Limsa Lominsa, it is normally at 21:00 ~ 0:00 in Japan. Fps goes down 44. I go to other area(There are one charator only). Fps goes up 59 fps. I return to crowed area. Fps goes down 44. I change shadows setting blow:
1.open system settings
2.open graphic settings
3.change shadows quality
Use low-detail models on shadows:enable
Shadow Resolution:1024
Shadow Cascading:best
Shadow Softening:strone
Shadows
Self: Show
Party Members: Hide
Other NPCs: Hide
Enemies: Hide
Fps goes up 59fps.
I use Intel arc a750 8gb and 2560*1440 display.
I change other settinges in graphics setting in ff14. Fps does not goes down at all.
P.S I use dxvk with ff14. Fps keep 60fps.
0 件の賞賛
7 返答(返信)
Jean_Intel
従業員
4,921件の閲覧回数
Hello matinekonya,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing issues playing FINAL FANTASY XIV.
  • Share a screenshot with the game video setting you have set.
  • Have you tried checking if the issue can be replicated in a different Area but with the same characters (142)?
  • If it is possible, recording a video showing the error would be ideal.
  • What distribution service did you get the game from (for example Steam / Origin / Epic / XboxGamePass / UbisoftConnect)?
  • To gather information about your system, such as Operating System Built, Driver, and BIOS versions; please, create a report using the Intel®️ System Support Utility (Intel®️ SSU).
    • Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
Jean O.
matinekonya
ビギナー
4,894件の閲覧回数
  • hare a screenshot with the game video setting you have set.
    ffxiv_20230304_215332_881.pngffxiv_20230304_215341_232.pngffxiv_20230304_215346_634.pngffxiv_20230304_215348_737.pngffxiv_20230304_220333_734.png
    Yes. I checked in Ul'dah and Old Sharlayan also.
    https://www.youtube.com/watch?v=ZpHPX78Y24g
    Steam
    I attached by ssu.txt
Jean_Intel
従業員
4,857件の閲覧回数
Hello matinekonya,
We appreciate your response.
Perform a clean installation of the latest production driver, 31.0.101.4146.  Sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected.
Also, Could you try changing the game language to English and provide us with the video settings screenshots once again?
Jean O.
matinekonya
ビギナー
4,844件の閲覧回数
I did but fps drop still.
ffxiv_20230307_210916_064.pngffxiv_20230307_210921_882.pngffxiv_20230307_210926_946.pngffxiv_20230307_210929_217.pngffxiv_20230307_210945_009.png
I notice funny thing. There are 200 charators in Bestway Burrows. But fps does not get drop at all. It keep 60 fps.
(15) ff14 fps does not drop in Bestway Burrows - YouTube
Jean_Intel
従業員
4,825件の閲覧回数
Hello matinekonya,
Thanks for the information provided.
We will do further research on this matter and post the response on this thread once we have further details.
Jean O.
Jean_Intel
従業員
4,773件の閲覧回数
Hello matinekonya,
We appreciate your patience.
We would like to inform you that we are already working on improving performance for this DX11 title (bug ID 18025525703); however, since this issue is very specific (only when certain conditions are met), it may not be picked up by the debug team.
We recommend you report it to the game developer as well since it might be an app issue.
We will now close the case. If you need additional information, please submit a new question, as this thread will no longer be monitored.
Jean O.
matinekonya
ビギナー
3,905件の閲覧回数
I reported ffxiv team and I update driver 5333.
FPS alomost keep 60 in GT.
FFXIV's benchmark show fps(min 53 fps and avg 104)
Thank you for supporting.
返信
