mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee2000000040110a
mce: [Hardware Error]: TSC 0 ADDR fef1ce80 MISC 43880014086
mce: [Hardware Error]: PROCESSOR 0:406e3 TIME 1546518486 SOCKET 0 APIC 0 microcode c6
mce: [Hardware Error]: Machine check events logged
mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee2000000040110a
mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 7880014086
These errors are shown every time I boot my laptop.
My laptop is running Arch Linux (kernel 4.20.1). But this happens with OS like Manjaro, Antergos, ArchLabs.
It doesn't do any harm, but if I want to load plymouth theme and add i915 to startup module, my laptop doesn't boot until I remove the line by chrooting.
It's worth noting that I do have:
extra/xf86-video-intel 1:2.99.917+859+g33ee0c3b-1 (xorg-drivers) [installed]
Processor info (lscpu):
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 78
Model name: Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
Stepping: 3
CPU MHz: 700.082
CPU max MHz: 2000.0000
CPU min MHz: 400.0000
BogoMIPS: 3985.00
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 3072K
NUMA node0 CPU(s): 0-3
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves dtherm arat pln pts hwp hwp_notify hwp_act_window hwp_epp flush_l1d
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [HD Graphics 520] (rev 07) (prog-if 00 [VGA controller]):
DeviceName: Onboard IGD
Subsystem: Dell Skylake GT2 [HD Graphics 520]
Flags: bus master, fast devsel, latency 0, IRQ 129
Memory at d0000000 (64-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [100] Process Address Space ID (PASID)
Capabilities: [200] Address Translation Service (ATS)
Capabilities: [300] Page Request Interface (PRI)
Kernel driver in use: i915
Kernel modules: i915
How can I fix this?
- Tags:
- Skylake
Ok, thanks. I might have to mount and look at Linux Mint/Ubuntu locally, because the plymouth works fine there. I do get these errors, but my system boots with the driver...
The error is on my Dell laptop. But my desktop also has Intel i3 processor (4th gen) where I installed plymouth on my own. It works fine. And also I get no error while booting my system or via journalctl...
It might be really a motherboard issue. Thank you.
![](/skins/images/2F496A9BF2E73260E2FDFDBCABF91248/responsive_peak/images/icon_anonymous_message.png)
