23832 Discussions
my screen is blinking randomly
AMahe2
my dell vostro v131 showing a probling continously, it blinks randomly, slighlty screen goes for micro seconds, but when i connect the chager it no longer blinks, please give me a solution
Kevin_M_Intel
Hello Asadullah,
Based on your description it seems the issue is being caused by a power management on your system. My best recommendation is for you to update the BIOS to latest and install the graphics driver provided by the Computer Manufacture. This OEM driver contains special changes for your computer so I strongly recommend you installing Dells driver.
Kevin M
JEFFREY_F_Intel
Try going into the Control Panel, select "On Battery".
Then try disabling Display Power Savings or reduce its aggressiveness (move slider toward max quality), select Apply.
You could also try disabling Display Refresh Rate Switching.if it is enabled.
See if either of these help.
