22943 Discussions
no HDMI video signal after system supend. HD2500 Windows7
CMart25
I've got a HD2500 in Windows 7.
When the system reactivates after suspend, HDMI signal is not present, I have to conect the monitor via VGA cable.
First of all: hardware is OK, because it works perfect under Linux.
After tens of tests, I think it must be the driver.
Help, please.
CMart25
Hello, I've updated the driver to the latest version, but the problem remains the same.
The only way I've found to not have the issue, is to install the generic VGA driver from MS Windows. But that is unacceptable, for the absence of hardware acceleration, or directx.
As mentioned, Linux has no problems.
I have this issue since I buy the PC.
Please, help.
Allan_J_Intel1
I just tested driver version 3345 on couple of Intel boards using HDMI connections, stand by and hibernation modes using different multi monitor settings and I was able to get video out of the HDMI.
I recommend checking with your computer manufacturer for customized drivers or even have them check HDMI ports on your computer.
Allan.
CMart25
Hello, I have made several tests. I have installed the latest driver: 10.18.10.3496.
The hardware is OK because it works 100% perfect undet Linux.
It must be a driver issue. What else?
Whenever ths PC awakes from suspend, the HDMI output is disabled.
The only way I have to activate hdmi output, is by reseting the driver with this script:
@echo off
cd c:\devcon
devcon restart *DEV_0152
After execute that, the HDMI output is activated again. So, it is the driver, isn't it?
Thank you
