22848 Discussions
no custom resolution in intel graphics control center
dolwpq
Hi all! I have a problem: there is no custom resolution in the intel graphics control center, and before that there was what to do, please tell me!
dolwpq
no
no
below 
Intel Graphics Control Center latest version
Andres_Intel
Hello dolwpq,
Thank you for posting on the Intel®️ communities. I see how important is for you to set a custom resolution in Intel® Graphics Command Center, I will be happy to help you.
To understand the issue in a better way, please answer the following questions:
Andres P.
dolwpq
no
no
below 
dolwpq
upd
Andres_Intel
Hello dolwpq,
Thank you for your response, and for the clarification.
Please follow the steps below, and then let me know if you are able to add a custom resolution:
  • Uninstall Intel® Graphics Command Center, by following the steps below:
  1. Press the Windows key.
    1. Click on settings.
    2. Select Apps and then select Apps & features.
    3. Search for Intel® Graphics Command Center.
    4. Click on it and select the option to uninstall.
Andres P.
GHALY
HELLO i tried this method but each time i try to put one they tell me "bad parameters"
dolwpq
Yes thank you🎉
Andres_Intel
Hello dolwpq,
Thank you for your response.
Happy to hear that the issue is fixed, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
