- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi all! I have a problem: there is no custom resolution in the intel graphics control center, and before that there was what to do, please tell me!
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello dolwpq,
Thank you for posting on the Intel®️ communities. I see how important is for you to set a custom resolution in Intel® Graphics Command Center, I will be happy to help you.
To understand the issue in a better way, please answer the following questions:
- Were you able to set a custom resolution before?
- Do you receive an error message? If so, what is the error message?
- To check you hardware information attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
- To know the Intel® Graphics Command Center version run the Report for Intel® Graphics Drivers, find the installation steps on How to Install the Intel® Graphics Command Center From the Microsoft Store.
Andres P.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello dolwpq,
Thank you for your response, and for the clarification.
Please follow the steps below, and then let me know if you are able to add a custom resolution:
- Uninstall Intel® Graphics Command Center, by following the steps below:
- Press the Windows key.
- Click on settings.
- Select Apps and then select Apps & features.
- Search for Intel® Graphics Command Center.
- Click on it and select the option to uninstall.
- Download Intel® Graphics Command Center (Beta). This option should be available in this version.
Andres P.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
HELLO i tried this method but each time i try to put one they tell me "bad parameters"
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello dolwpq,
Thank you for your response.
Happy to hear that the issue is fixed, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
