Hello, I'll explain the problem I'm having:
About 3 months ago, I built a new PC:
Case: Lian Li O11 Mini Air Black.
Motherboard: ASUS TUF GAMING B860M-PLUS.
Processor: Intel Core Ultra 7 265KF.
Liquid Cooling: Lian Li AIO with LCD screen.
RAM: 2 x 16GB G.Skill DDR5 RIPJAWS S5 modules in slots A2 and B2.
Graphics Card: NVIDIA 3060.
Power Supply: Cooler Master SFX 850W ATX 3.0
Storage: 1 M.2 boot drive and 3 mechanical hard drives (HDDs).
One day, the 3060 stopped displaying an image when I turned on the PC. Without further testing, I bought the 5070, as I already intended to upgrade, and it started working correctly. It worked fine for two weeks until it did the same thing again: no image on startup.
I ran several tests, including installing the 3060, which fits in the slower PCI Express slot, and I got a display. However, after turning it off and on again one afternoon while testing, the same problem persisted: no image. I even got a display in the faster PCI Express slot, but nothing changed; it failed again on the first restart.
After that, I replaced the motherboard under warranty and bought a Corsair SFX 850W, ATX 3.1.
After reassembling everything today, we're still having the same problem. I've swapped RAM modules, removed one, and it's still the same. I've tried connecting it via HDMI to my Dell monitor and TV, and nothing. I've tried three different DisplayPort cables, and still nothing.
The motherboard's status LEDs stay green during boot.
Do you know what the problem could be or how I can proceed?
