23783 Discussions
non-functional touch screen
MS0088
Dear all,
I have been struggling with a non-functional touch screen for some time, which stopped working after updating WINDOWS 10. I update from build 19 to 21.
I installed the drivers see the link, but unfortunately it didn't help. 
https://www.intel.com/content/www/us/en/products/sku/128992/intel-celeron-j4005-processor-4m-cache-up-to-2-70-ghz/downloads.html
Is there any way to fix the touch screen with the current build? Or do I have to play on an old OP system?
I attach the PC configuration:
AlHill
Contact fujitsu for the driver.
[Waiting for Windows 12]
megan3000
Valued Contributor I
AlHill is correct...
A system with a touchscreen most likely has special customizations that are addressed/enabled through custom drivers... Unlike the drivers from Intel that are generic, the custom drivers are provided only by the specific manufacturers...
Your manufacturer is Fujitsu but your decided to download the driver from Intel...
Your first option should always be to look for and download drivers from Fujitsu website... if they don't have any newer driver or if the issue persists, you should ask Microsoft since you have said "it was their Windows update or the update process that broke this... (nothing new here with Windows updates 🙄😑)
MS0088
Thank you for your response, and for guidance. The FUJITSU BIOS update seems to have helped.
megan3000
Glad to know that the BIOS update helped...
