23801 Discussions
not recognizing HDMI Inted HD Graphics 620
YRich
My computer suddenly stopped connecting to HDMI.
It doesn't even recognize the connection.
Have tried to update drivers, roll back drivers, disable and enable the device and nothing works.
I am a teacher and use my smartboard all the time and this is very aggravating
Please help
n_scott_pearson
Have you tried the simple things, like replacing the HDNI cable? [this happens more often that you would think]
Have you tried connecting a different output device (a simple monitor)?
YRich
Sirry
Yes. I've switched cables. I've also tried other computers on the same cable and monitor which work.
Tried other monitors And projectors.
My computer is not recognising the any HDMI devices
Hello ydr770,
Thank you for contacting us regarding the compatibility issue that you have been experiencing with the HDMI interface of your machine, it will be more than a pleasure to provide you with assistance on this matter.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel System Support Utility will generate through:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click •Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
I hope to hear from you soon.
Diego S.
YRich
Hi
Here is the system information
Hello ydr770,
Thank you your response.
I was taking a look to the report that you attached to us, we really appreciate it.
I was able to notice that your OEM device has an Intel(R) Core(TM) i7-7500U CPU that uses Intel® HD Graphics 620. The drivers currently installed on your machine are the OEM Driver Version: "22.20.16.4815" which seems to be out of date.
You can find the latest generic drivers for your graphics controller here:
https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=96551 https://downloadcenter.intel.com/download/27484/Graphics-Intel-Graphics-Driver-for-Windows-15-65-?product=96551
Feel free to go ahead and download our .exe file in order to update the generic drivers and monitor the results.
If by any chance the issue persists I strongly recommend you to contact the manufacturer of you equipment due to the fact that their drivers are customized for your machine while on the other hand, our drivers are generic.
A BIOS update could be recommended as well depending on the results of the performance on their drivers, however that type of support will be available only through them at:
https://support.lenovo.com/us/en/ https://support.lenovo.com/us/en/
Hope this helps,
Diego S.
Hello ydr770,
I was taking a look to your thread, and I wanted to confirm if you need further assistance?
Please do not hesitate on replying back so we can provide you with assistance regarding your issue.
Diego S.
