22972 Discussions
opencl 2.0 support added to iris 5100
gbhj
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue AND 'does it fail every single time, or only sometimes?' If you can offer a % rate please do.
after updating to driver version 20.19.15.4352 applications (including the Intel® Iris™ Graphics Control Panel) have started to detect the iris 5100 as an openCL 2.0 device. applications that require openCL 2.0 have being working with this new driver.
Hardware (HW)
Brand and Model of the system.
HP Pavilion 15 Notebook PC
Hybrid or switchable graphics system? ie Does it have AMD or NV graphics too?
no
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
LFP 1366 x 768 (32 bit) (60Hz) SDC4951
How much memory [RAM] in the system (see note2 below).
8192MB RAM
Provide any other hardware needed to replicate the issue.
ie: Cables&brand, cable type [vga, hdmi, DP, etc], dock, dongles/adapters, etc
<span style="font-size: 10pt; ...
