Hello everyone. I work in a hardware store, and I had the opportunity to test the mobile version of the intel arc a530m. Stands in a Lenovo Loq 15IAX9I (83FQ002FRA) Luna Gray laptop. The model has a very high-quality display and immediately catches the eye. Finding some free time, I conducted tests in comparison with the Rtx3050 from different laptop manufacturers. Unfortunately, intel Arc a530m is inferior in everything, only in benchmarks it scores a close number of points. But in the game Stalker 2, the heart of Chernobyl is generally a rout. 3050 4gb can be played on middle settings with dlss on the quality without frame generation, and get 50-60 frames. at that time, on the intel arc a530m, we have an unplayable 18-20 fps on the lowest settings with xess or fsr. I used the beta driver but didn't get a bit more performance. Intel Arc GPU Graphics Drivers 101.6299 Beta. Will there be an increase in productivity due to drivers in the future?
Hi ArcTester95,
Thank you for posting in the community and for your feedback about the Arc A530M. I will take note of this, but to further analyze the situation, can you provide the following information for me:
- First I will be needing to get your Laptops full information, to get that please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here. How to get the Intel® System Support Utility Logs on Windows
- Can you provide a screen shot of your game settings?
- What variant of display do you have on this laptop the 1080p or 1440p?
- What is the maximum refresh rate you currently set on your laptop display?
Lastly, can you use CapFrameX to record the FPS data for the game you are testing? You can follow this link for the steps on how to download, install, and set up CapFrameX. Just scroll down until you find the steps for CapframeX: https://community.intel.com/t5/Intel-ARC-Graphics/Need-help-Reporting-a-bug-or-issue-with-Arc-GPU-PLEASE-READ-THIS/td-p/1494429
Dhanniel M.
Hi ArcTester95,
I wanted to check if you have the chance to review the questions that I have posted. Let me know if at your earliest convenience so we can determine the next course of action to resolve this matter.
Dhanniel M.
Hi ArcTester95,
Dhanniel M.
