22936 Discussions
¿porque luego de actualizar el controlador de video intel hd 4000 no funciona el brillo de pantalla?
pnava
instale la actualizacion que tenia disponible con el asistente de controlador y asistencia de intel y una vez acabada la instalacion el brillo de la pantalla se bajo al minimo y no funciona ni subirlo con algun boton, asi como desde el control de energia
de antemano gracias por las respuestas
Lainu: Thank you very much for contacting the Intel® Graphics communities. We will do our best in order to try to fix this problem.
In regard to your question, is it difficult to explain why the brightness feature is not working properly after updating the graphics controller, it could be due to a compatibility problem with the driver installed. Just to let you know, the Intel graphics drivers are generic, meaning they might or might not work with your system, that is why we recommend to install the drivers provided by the manufacturer of the computer.
Since processor works with Intel® HD graphics 4000, we can try to install the latest version of the graphics driver for that controller which is 4653:
https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499 https://downloadcenter.intel.com/download/26813/Intel-Graphics-Driver-for-Windows-15-33-?product=81499
If the problem persists after that, to re-install the drivers or a BIOS update might be needed. In that case the best thing to do will be to get in contact with the manufacturer of the device directly.
Also, as an option you can always get in contact with Microsoft directly to get further assistance on this scenario:
https://support.microsoft.com/en-us/contactus/ https://support.microsoft.com/en-us/contactus/
Any further questions, please let me know.
Alberto R
pnava
Luego de instalar la versión anterior, se corrigió el error y funciona todo como corresponde.
Muchas gracias por la respuesta, fue de mucha ayuda
Lainu: You are very welcome. Thank you for letting us know those results, we are glad to hear the problem got resolved.
Any other inquiry, do not hesitate in contact us again.
Alberto R
