23785 Discussions
problem with new update
welljohnson
I can't do the new update from intel graphics, I do the normal download from intel dsa and when installing the application it doesn't respond.
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
welljohnson
ok, I already put the text file
AndrewG_Intel
Hello @welljohnson
In regards to this issue, we understand you have opened an internal Web Ticket with us and Intel Customer Support has already assisted you through that channel. We will therefore close this community case in order to avoid duplication of efforts. Thank you.
Andrew G.
