22882 Discussions
"NF I2C Slave Dvice" appears in the device manager when graphics driver has been installed
mocelise
When I have installed the  latest graphics driver for Arc B580,this "NF I2C Slave Device" appeared in device manager.
My PC hardwares:
CPU: R9 5950X
Motherboard:ASUS X570-E Gaming WiFi II
Mem:16GB*2
All the Drivers and BIOS have been updated to the latest version,but this unkown device is allways exists.How to fix this issue?
DhannielM_Intel
Hello mocelise,
Thanks for posting in the community. To further assist you, I have a few questions. Please see them below:
  1. Can you tell me the exact brand name of your B580?
  2. Is this the first Intel GPU you have, or did you have a different GPU before?
  3. Have you performed a clean installation of the graphics driver, especially using the Display Driver Uninstaller (DDU)?
  4. Is your Smart Access Memory enabled in your BIOS?
  5. Are you experiencing any errors or issues when using your system?
Also, to better understand your entire system information, please use the System Support Utility (SSU). This will generate a text file that compiles all your system information. You can follow this link for instructions and send the text file here: Help Guide for the Intel® System Support Utility
Dhanniel M.
mocelise
1.GUNNIR Intel Arc B580 Photon 12G OC Graphics
2.I have an ASUS Daul RTX3050 8G before.
3.I have cleaned the driver of RTX 3050 by DDU before installing B580,When I found out that this unknown device existed, I even reinstalled win11_x64_24H2.But it didn't works.
4.I have enabled "resizable bar" in BIOS.
5.There are't any errors or issues except this one.
I don't where to send or submit the text file that generated by SSU.
senses_FAIL
Same problem with mine...
Earl_Intel
Hi mocelise,
Thank you for providing this information with us, I will further check on this internally.
You can send the Intel SSU logs on this thread when you post, this will further help us on the investigation regarding to your concern.
Source link: Intel® System Support Utility for Windows*
Earl E.
mocelise
Hi Earl E,
Thanks for your attention,here's the text file that generated by SSU.
Earl_Intel
Hi mocelise,
Thank you for providing the SSU logs, I will further check on this internally.
I will provide an update on this thread as soon as possible.
Best regards.
Earl E.
Earl_Intel
Hi mocelise,
Thank you for patiently waiting.
To further troubleshoot the issue, please try the following steps:
1. Update Drivers: Right-click on the NF I2C Slave device in Device Manager and select 'Update driver.' Choose 'Search automatically for drivers' to allow Windows to find and install the appropriate driver. If the issue persists, proceed to step 2.
2. Use Display Driver Uninstaller (DDU) to remove the current graphics driver, then install the latest graphics driver version 32.0.101.6332_101.6253 (Latest).
3. If the issue continues, please take a screenshot of the error message displayed under the Device status of the NF I2C Slave Device.
Earl E.
Earl_Intel
Hi mocelise,
I wanted to check if you had the chance to review the troubleshooting steps I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Earl E.
mocelise
Hi Earl_Intel,
Thanks for help,I have tried the steps,but it didn't work.I have installed the latest driver "gfx_win_101.6449_101.6256"with WHQL.Here's the screenshots:
Snipaste_2025-01-07_19-03-18.pngSnipaste_2025-01-07_18-49-43.pngSnipaste_2025-01-07_19-05-22.pngSnipaste_2025-01-07_19-05-18.png
DaxSe7en
Hi mocelise,
i had the same problem with the Intel Arc B580 Steel Series from AsRock.
it seems that the NF I2C Slave Device is the RGB contoller driver for the graphics card RGB lighting.
i´ve downloaded  and installed the AsRock Polychrome sync software and the missing device was found.
maybe Gunnir had a similar software.
hope it helps
best regards,
DaxSe7en
mocelise
Hi DaxSe7en,
Thanks for your suggestion,Gunnir official support haven't released related software about this issue.
Earl_Intel
Hi mocelise,
I appreciate you sharing the screenshots of the problem. Don't worry, I'll check them over and get back to you on this thread as soon as I can.
Earl E.
Earl_Intel
Hi mocelise,
It is true that this "NF I2C Slave Device" is the RGB controller driver for the RGB graphics card illumination.
With that being said, its best to wait for the response of Gunnir Official Support for the drivers.
Earl E.
Ma11owMarsh
Try to install this driver manually through the device manager.
Although I didn't find out any difference after installing this driver, but this get rid of the annoying exclamation in the device manager at least.
Also may be remember to uninstall this driver first when Gunnir release their official support for the RGB controller.
