Hello, Good day! can you help me about these problem "display driver intel hd graphics for windows 8 (r) stop responding and has recovered" everytime i play game.. this problem starts when i got win10. but before it was okay when i had win8..
- Tags:
- Drivers
Im using: Dell inspiron 5547
BIOS - A07
Processor - intel (r) core(TM) i7-4510u CPU @ 2.00Ghz (4CPUs), ~2.6Ghz
Memory - 8192MB RAM
Display - Intel(r) HD Graphics
System type - 64-bit operating system, x64based processor
Please try this driver:
https://downloadcenter.intel.com/download/25308/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-4th-Gen-Windows-10-64bit https://downloadcenter.intel.com/download/25308/Intel-Iris-Iris-Pro-and-HD-Graphics-Driver-for-4th-Gen-Windows-10-64bit
If you are having problems to install this driver, you may try these steps:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
Kevin M
Hi kevin, im still experiencing the problem after i download the new driver.. this is what happen when i play coc and other games, even skype.. the apps hang or freeze and the then the notification pop up just like in this picture
Try turning off the 'Conservative Morphological Anti-Aliasing' setting under '3D' as a workaround.
Hi seemebreakthis.. still experiencing the problem.. i dont know what happen,its just started when i upgraded from win8 to win10.. right now i cant use 2 apps at the same time, for example, coc ,ragnarok,dota2, or even skype.. but before i can open these apps at the same time.. thanks anyways.
Hello Xinn,
I would recommend to install the latest version of the Graphics Driver from our site, please visit https://downloadcenter.intel.com/download/25489/Intel-Graphics-Driver-for-Windows-10-15-40-4th-Gen- Download Intel® Graphics Driver for Windows® 10 [15.40][4th Gen], I would also recommend performing a manual installation of the driver. Here are the instructions for the Manual Installation http://www.intel.com/support/graphics/sb/CS-033916.htm Desktop graphics drivers — How to Manually Install a Driver in Microsoft Windows 8* or Windows 8.1*
Here is a helpful link that might help you to fix this issue;
http://www.drivethelife.com/windows-drivers/how-to-fix-display-driver-stopped-responding-and-has-recovered-on-windows-10-8-7-xp-vista.html How to Fix the "Display Driver Stopped Responding and Has Recovered" Error | OSToto.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
For further information you can check the following link http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft*.
Amy.
![](/skins/images/7B0AB6865064EAE32B30EC9A4E94B48A/responsive_peak/images/icon_anonymous_message.png)
