23804 Discussions
run in windows iso
enginbey8108
can you write windows iso setupchipset.exe silent command bat to run windows 10 isoda parameter -s to run in username without desktop
Carlos_L_Intel
Hi @enginbey8108,
Thank you for posting on the Intel® communities.
 In this case, I believe you are referring to the chipset driver installation. In this case, this is provided by the motherboard manufacturer. If you need support, please refer to their support, so you can get accurate information.
Carlos L.
enginbey8108
how can i integrate full windows iso to install chipset full
Carlos_L_Intel
Hi @enginbey8108,
 Thanks for your question. For this, you will need to contact the motherboard manufacturer you are working with, to see if this is possible.
Are there any other questions I could assist with, or would you like me to close this thread?
Carlos L.
Carlos_L_Intel
Hi @enginbey8108,
Were you able to check the previous post? Let us know if you still need assistance.
Carlos L.
Carlos_L_Intel
Hi @enginbey8108,
Carlos L.
