22749 Discussions
slow typing speed on acer happy 2, please help!
Hi, I recently got an Acer aspire one happy 2 netbook, and when i installed the OS I noticed that the whole system got painfully slow when typing. Otherwise everything is working fine, the problem occurs ONLY when trying to type something in any program. I have encountered the same problem on a Dell laptop and it turned out that the reason was a service called ATI hotkey poller and was connected to the graphics card drivers, but this videocard is Intel's. I will be very grateful for any ideas on how to solve the problem or the name of the service that is causing it /if that's the case at all/.
DArce
Valued Contributor III
We have have not seen any related issues with any of our video controllers. I suggest you to check on this problem directly with your system manufacturer at:
http://support.acer.com/us/en/default.aspx http://support.acer.com/us/en/default.aspx
